[GRASS-user] azimuth of lines with v.to.db?
    Carlos "Guâno" Grohmann
    carlos.grohmann at gmail.com
    Mon Apr  6 13:56:45 EDT 2009
Hello.
I did a full up of my develbranch but couldn't use  the azimuth option:
 > v.to.db map=lineamentos type=line option=azimuth units=degrees
columns=azimute
ERROR: value <azimuth> out of range for parameter <option>
       Legal range:
cat,area,compact,fd,perimeter,length,count,coor,start,end,sides,query,slope,sinuous
ERROR: value <degrees> out of range for parameter <units>
       Legal range: mi,miles,f,feet,me,meters,k,kilometers,a,acres,h,hectares
cheers
carlos
On Mon, Mar 30, 2009 at 09:36, Maris Nartiss <maris.gis at gmail.com> wrote:
> Hello all.
> I also needed to do some lineament orientation analysis and to do so I
> modified v.to.db [1]. Now it supports calculating line azimuths as CW
> direction from line start point to line endpoint.
> Usage example:
> v.to.db map=lineaments type=line option=azimuth units=degrees
> columns=orientation
> svn up Your develbranch6 and test it :)
> Maris.
> 1. http://trac.osgeo.org/grass/changeset/36528
Carlos Henrique Grohmann - Geologist D.Sc.
a.k.a. Guano - Linux User #89721
ResearcherID: A-9030-2008
carlos dot grohmann at gmail dot com
http://www.igc.usp.br/pessoais/guano/
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
Can’t stop the signal.
