[GRASS-user] v.in.db accept DECIMAL'S?
Moritz Lennert
mlennert at club.worldonline.be
Tue Apr 7 15:25:44 EDT 2009
On 07/04/09 21:11, Jhon Ortiz wrote:
> > On Tue, Apr 7, 2009 at 9:25 AM, Markus Neteler <neteler at osgeo.org> wrote:
> > > On Tue, Apr 7, 2009 at 12:47 AM, Jhon Ortiz
> <eljhonjhon at hotmail.com> wrote:
> > >> Hi all,
> > >> I'm trying to create a new vector (points) map from a mysql
> database table
> > >> v.in.db --overwrite table=data_wells driver=mysql
> > >> database="host=localhost,dbname=Eoceno" x=Este y=Norte
> z=Salinity_Index
> > >> key=Cat output=Pozos
> > >> but I get this error:
> > >> WARNING: MySQL driver: column 'Salinity_Index', type 246 is not
> supported
> > > I have searched that and found
> > > grep 246 /usr/include/mysql/mysql_com.h
> > > MYSQL_TYPE_NEWDECIMAL=246,
> > > I suspect that this change is sufficient to solve the problem:
> > > --- db/drivers/mysql/describe.c (revision 36267)
> > > +++ db/drivers/mysql/describe.c (working copy)
> > > @@ -177,6 +177,7 @@
> > > break;
> > > case MYSQL_TYPE_DECIMAL:
> > > + case MYSQL_TYPE_NEWDECIMAL:
> > > *sqltype = DB_SQL_TYPE_DECIMAL;
> > > break;
> > Ah, I already suggested it in 2007 to someone else but there was
> > no feedback:
> https://wald.intevation.org/tracker/index.php?func=detail&aid=524&group_id=21&atid=204
> > > Do you have a possibility to compile and test?
> > Please :) Or someone else with a running Mysql installation.
> Thanks for your help Markus,
> I change in
> break;
> and then compiled..
> Now, when I tried
> x=Este y=Norte z=Salinity_Index key=Cat output=Pozos3
> The error is:
> Writing features...
> ERROR: x/y/z column must be integer or double
> I change the decimal type by double in mi MySQL database table and now
> is working..
The following (in combination with Marjus' patch) might make it work
with decimal:
Index: lib/db/dbmi_base/sqlCtype.c
--- lib/db/dbmi_base/sqlCtype.c (révision 36609)
+++ lib/db/dbmi_base/sqlCtype.c (copie de travail)
@@ -17,6 +17,8 @@
return DB_C_TYPE_DOUBLE;
case DB_SQL_TYPE_DOUBLE_PRECISION:
+ case DB_SQL_TYPE_DECIMAL:
+ return DB_C_TYPE_DOUBLE;
case DB_SQL_TYPE_SERIAL:
return DB_C_TYPE_INT;
But I'm not sure whether it might have any negative consequences to
automatically associate decimal with double. I can't think of anything
obvious, but needs testing.
Moritz
