[GRASS-user] Moving GISBASE box2box
    Cassiel
    raffaele.morelli at gmail.com
    Wed Apr  8 07:58:37 EDT 2009
Hi you all,
I am having troubles in moving my GISBASE dir between two linux boxes.
At grass startup, once I select the gisbase dir, every mapset I try to
access results in this error message "this is not a valid mapset".
Creating a new location works.
Is there any trick to fix this issue? I guess it's something trivial but I
don't know what it can be, moreover I did it before and everything worked
fine.
GRASS 6.3.0.1 from gfoss repos  (grass_6.3.0.1~gfossit20090217-1_amd64.deb)
The linux boxes are up with debian lenny amd64 (though the one I am
migrating to is a quad core intel xeon and the other one a dual core amd64)
regards
r
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090408/6c487009/attachment.html
