[GRASS-user] working on a mounted external disk
    Vincent Bain
    bain at toraval.fr
    Wed Apr  8 08:13:03 EDT 2009
OH, that simple ! shame on me :-(
Sorry for being so dazed...
A detail concerning r.proj in that context of distinct gisdbases :
if the distant location has the same name as the current (i.e. in my
example both locations are called 'my_location'), then the command
returns a comprehensible error :
ERROR: You have to use a different location for input than the current
It would be nice if the dbase argument was checked /before/ the location
argument, in order to admit same location names, not necessarily meaning
that we project data in an identical projection system.
Vincent
Le mercredi 08 avril 2009 à 13:41 +0200, Moritz Lennert a écrit :
> this should be:
> r.proj input=dem50 location=my_location
>           mapset=topo dbase=/mnt/path_to_my_disk/ output=dem50
> If you give it location=/mnt/path_to_my_disk/my_location
> it "thinks" that the location is called
> "/mnt/path_to_my_disk/my_location" as the error message indicates:
> ERREUR :Mapset <topo> in input location
>          </mnt/path_to_my_disk/my_location/> - not found
> Moritz
