[GRASS-user] Moving GISBASE box2box
Moritz Lennert mlennert at club.worldonline.be
Thu Apr 9 06:11:19 EDT 2009
On 09/04/09 11:17, Cassiel wrote:
> Hi,
> each and every location dir belong to my user, which in turn is the
> same on every machine I am allowed to log in.
> WINDOWS file are there with the same permissions
> ... I can't figure out why this worked in past and now it seems
> broken
> Other hints?
In your first post you wrote:
> At grass startup, once I select the gisbase dir, every mapset I try
> to access results in this error message "this is not a valid mapset".
If this is the exact error message, then the only place I can find this
in the source code is in lib/init/gis_set.tcl as a result of a failed
CheckMapset, which is just:
proc CheckMapset {} {
         global database location mapset
         if { $mapset == "" } { return 0; }
         if { [file exists "$database/$location/$mapset/WIND"] } {
                 return 1
         return 0
So, it fails either if the mapset variable is empty, or if there is no
WIND file in the mapset (or at least if file exists returns 0 - don't
know in which cases it does this).
Are you sure that the gis-database is correclty defined ?
Have you tried accessing the mapsets directly on the command line
without going through the GUI ?
Moritz
