[GRASS-user] [SOLVED] was Moving GISBASE box2box
Moritz Lennert
mlennert at club.worldonline.be
Thu Apr 9 06:43:11 EDT 2009
On 09/04/09 12:24, Cassiel wrote:
> 2009/4/9 Moritz Lennert <mlennert at club.worldonline.be
> <mailto:mlennert at club.worldonline.be>>
> On 09/04/09 11:17, Cassiel wrote:
> Hi,
> each and every location dir belong to my user, which in turn is the
> same on every machine I am allowed to log in.
> WINDOWS file are there with the same permissions
> ... I can't figure out why this worked in past and now it seems
> broken
> Other hints?
> In your first post you wrote:
> At grass startup, once I select the gisbase dir, every mapset I try
> to access results in this error message "this is not a valid
> mapset".
> If this is the exact error message, then the only place I can find
> this in the source code is in lib/init/gis_set.tcl as a result of a
> failed CheckMapset, which is just:
> proc CheckMapset {} {
> global database location mapset
> if { $mapset == "" } { return 0; }
> if { [file exists "$database/$location/$mapset/WIND"] } {
> return 1
> return 0
> So, it fails either if the mapset variable is empty, or if there is
> no WIND file in the mapset (or at least if file exists returns 0 -
> don't know in which cases it does this).
> Are you sure that the gis-database is correclty defined ?
> Have you tried accessing the mapsets directly on the command line
> without going through the GUI ?
> Moritz
> Hi,
> I finally solved looking the location dirs side by side with mc.
> Moving from the old machine on the removable drive and from the latter
> to the newer machine changed the case of the VAR and WIND file inside
> the location dirs. What sounds very strange to me is why only those two
> files plus a MYNAME one...
Did you have other upper-case names which remained upper-case ?
Maybe an issue with a fat filesystem on the removable drive ?
Moritz
