[GRASS-user] i.landsat.acca addon installing
Patrick Giraudoux
patrick.giraudoux at univ-fcomte.fr
Sat Apr 11 02:21:57 EDT 2009
Sorry to insist resending this message, but I would really appreciate
if someone can give me a clue to get out of this and be capable to add
i.landsta.acca to GRASS
Thanks in advance,
Patrick
Dear listers,
I would like to install the add-on i.landsat.acca, and for that have
carefully read the instructions at
http://trac.osgeo.org/grass/browser/grass-addons/README, which states:
* C code/Scripts, with GRASS binaries on your computer:
compile GRASS Addons modules into your GRASS code by setting
MODULE_TOPDIR to where to the GRASS binaries are located:
make MODULE_TOPDIR=/usr/lib/grass640/
I am working under Ubuntu hardy, with a precompiled version of GRASS
6.3.0. I have put those files in a folder:
algorithm.c description.html local_proto.h main.c Makefile tools.c
and from this folder:
pgiraudo at pgiraudo-laptop:~/GrassAddon$ sudo make
MODULE_TOPDIR=/usr/lib/grass/
then I get a long list of errors (see below) and does not know at all
from where to start to fix it...
Any idea about what to do ?
Patrick
[sudo] password for pgiraudo:
gcc -I/home/jachym/src/grass/grass-6.3.0/dist.i486-pc-linux-gnu/include
-Wall -g -D_FILE_OFFSET_BITS=64 -O2 -DPACKAGE=\""grassmods"\"
-I/home/jachym/src/grass/grass-6.3.0/dist.i486-pc-linux-gnu/include -o
OBJ.i486-pc-linux-gnu/algorithm.o -c algorithm.c
algorithm.c:6:23: erreur: grass/gis.h : Aucun fichier ou dossier de ce type
algorithm.c:7:27: erreur: grass/glocale.h : Aucun fichier ou dossier de
ce type
algorithm.c: Dans la fonction «acca_first» :
algorithm.c:220: attention : déclaration implicite de la fonction «
«G_allocate_raster_buf» »
algorithm.c:220: erreur: «CELL_TYPE» undeclared (first use in this function)
algorithm.c:220: erreur: (Each undeclared identifier is reported only once
algorithm.c:220: erreur: for each function it appears in.)
algorithm.c:220: attention : assignment makes pointer from integer
without a cast
algorithm.c:221: attention : déclaration implicite de la fonction «
«G_open_raster_new» »
algorithm.c:222: attention : déclaration implicite de la fonction «
«G_fatal_error» »
algorithm.c:222: attention : déclaration implicite de la fonction « «_» »
algorithm.c:232: attention : déclaration implicite de la fonction «
«G_window_rows» »
algorithm.c:233: attention : déclaration implicite de la fonction «
«G_window_cols» »
algorithm.c:239: attention : déclaration implicite de la fonction «
«G_percent» »
algorithm.c:243: attention : déclaration implicite de la fonction «
«G_get_d_raster_row» »
algorithm.c:252: attention : déclaration implicite de la fonction «
«G_is_d_null_value» »
algorithm.c:252: erreur: «DCELL» undeclared (first use in this function)
algorithm.c:252: erreur: expected expression before «)» token
algorithm.c:257: erreur: expected expression before «)» token
algorithm.c:329: attention : déclaration implicite de la fonction «
«G_set_c_null_value» »
algorithm.c:329: erreur: «CELL» undeclared (first use in this function)
algorithm.c:329: erreur: expected expression before «)» token
algorithm.c:333: erreur: expected expression before «)» token
algorithm.c:336: attention : déclaration implicite de la fonction «
«G_put_raster_row» »
algorithm.c:343: attention : déclaration implicite de la fonction «
«G_free» »
algorithm.c:344: attention : déclaration implicite de la fonction «
«G_close_cell» »
algorithm.c: Dans la fonction «acca_second» :
algorithm.c:361: attention : déclaration implicite de la fonction «
«G_find_cell2» »
algorithm.c:361: attention : assignment makes pointer from integer
without a cast
algorithm.c:364: erreur: «CELL_TYPE» undeclared (first use in this function)
algorithm.c:364: attention : assignment makes pointer from integer
without a cast
algorithm.c:365: attention : déclaration implicite de la fonction «
«G_open_cell_old» »
algorithm.c:370: attention : assignment makes pointer from integer
without a cast
algorithm.c:390: attention : déclaration implicite de la fonction «
«G_get_c_raster_row» »
algorithm.c:395: attention : déclaration implicite de la fonction «
«G_is_c_null_value» »
algorithm.c:395: erreur: «CELL» undeclared (first use in this function)
algorithm.c:395: erreur: expected expression before «)» token
algorithm.c:397: erreur: expected expression before «)» token
algorithm.c:401: erreur: expected expression before «)» token
algorithm.c:404: attention : parenthèses suggérées autour de && à
l'intérieur de ||
algorithm.c:406: erreur: «DCELL» undeclared (first use in this function)
algorithm.c:406: erreur: expected expression before «)» token
algorithm.c:409: erreur: expected expression before «)» token
algorithm.c:414: erreur: expected expression before «)» token
algorithm.c:416: erreur: expected expression before «)» token
algorithm.c:422: attention : parenthèses suggérées autour de && à
l'intérieur de ||
algorithm.c:424: erreur: expected expression before «)» token
algorithm.c:427: erreur: expected expression before «)» token
algorithm.c:444: attention : déclaration implicite de la fonction «
«G_remove» »
algorithm.c:450: attention : déclaration implicite de la fonction «
«G_rename» »
algorithm.c:353: attention : unused variable «i»
make: *** [OBJ.i486-pc-linux-gnu/algorithm.o] Erreur 1
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090411/b09c69fd/attachment-0001.html
