[GRASS-user] i.landsat.acca addon installing
Markus Neteler
neteler at osgeo.org
Sun Apr 12 03:07:02 EDT 2009
2009/4/12 Patrick Giraudoux <patrick.giraudoux at univ-fcomte.fr>:
> Yahoooooooo ! Works perfectly !!!
Excellent!
> Furthermore I have understood lots of things during the process about GRASS
> architecture and functionning (better late than never ;-) ).
And never give up :)
> May I suggest to insert a line describing this last "copy" step in the
> Readme at http://svn.osgeo.org/grass/grass-addons/README
> * C code/Scripts, with GRASS binaries on your computer:
> compile GRASS Addons modules into your GRASS code by setting
> MODULE_TOPDIR to where to the GRASS binaries are located:
> make MODULE_TOPDIR=/usr/lib/grass640/
> then copy the module created in XXXX to YYYY
Will perhaps do that, or just submit my proposed change which will
permits to simply do
make MODULE_TOPDIR=/usr/lib/grass640/ install
best
Markus
