[GRASS-user] traveling salesman problem in air
Martina Schäfer
Martina.Schafer at ebc.uu.se
Wed Apr 15 03:46:08 EDT 2009
Yes, the centroids should be fine. it actually did not work to run
v.net.visibility when I tried but I'll give it another try with the
centroids.
Thanks!
Martina
Moritz Lennert skrev:
> On 15/04/09 09:19, Wolf Bergenheim wrote:
>> On 15.04.2009 10:05, Moritz Lennert wrote:
>>> On 15/04/09 08:55, Martina Schäfer wrote:
>>>> Dear GRASS experts!
>>>> I encountered an interesting problem and am curious about solutions.
>>>> A helicopter company has got a file from a client regarding a forest
>>>> inventory. The file contains 1430 polygons representing areas to be
>>>> visited. Now we want to calculate the optimal route to visit all
>>>> polygons. In contrast to a traveling salesman , we don't have a
>>>> network of routes as the helicopter can fly everywhere. Would it be a
>>>> solution to have the distance betweeen areas as the "cost"?
>>>> I used a tool in MapInfo that connects successive closest points which
>>>> worked very nice but not optimal.
>>>> Anyone knows of other solutions?
>>> Maybe v.net.visibility to create a network and then v.net.salesman ?
>> Exactly what I was going to suggest. the network created by
>> v.net.visibility will connect all polygon nodes to all visible polygon
>> nodes. The net will then consist of of these points plus the edges that
>> make up the polygons.
> Depending on the size of the polygons and of the whole area, I imagine
> that this could be simplified by just using the centroids of the
> polygons, or ?
> Moritz
