[GRASS-user] ascii dem opening?
espiritoCZ
espiritocz at gmail.com
Tue Apr 21 05:45:57 EDT 2009
Ok, thanks to both,
I was quite sure that it would be a piece a cake for you :)
All the best!
Milan
(not tried yet, but i believe i will manage now)
Hamish wrote:
> espiritoCZ wrote:
>> > The file structure is very simple:
>> > X [tab] Y [tab] Z
>> > (e.g.:
>> > 23.3375 45.8959 -2.345
> Markus:
>> I have tried the line you have indicated and stored it as
>> file points.csv. Then imported with:
>> v.in.ascii -z in=points.csv out=points3d x=1 y=2 z=3 fs=tab
> also r.in.xyz could help if it is millions of points or
> pre-gridded.
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://n2.nabble.com/ascii-dem-opening--tp2664060p2668981.html
Sent from the Grass - Users mailing list archive at Nabble.com.
