[GRASS-user] Rotate a map display
Cuinet Jérôme
jerome at georezo.net
Tue Apr 21 15:03:01 EDT 2009
Thanks for your responses,
I realize that I don't need a GIS such as Grass which is like other GIS a
system intended for geographic database users, not for map users.
I need a map server, and so I think that MapServer is a better solution for
my needs
----- Original Message -----
To: "Jérôme - GeoRezo.net" <jerome at georezo.net>; "Vincent Bain"
<bain at toraval.fr>
Cc: <grass-user at lists.osgeo.org>
Sent: Thursday, April 16, 2009 9:39 AM
Subject: Re: [GRASS-user] Rotate a map display
Vincent wrote:
> If you need to warp a map for a strict display purpose, IMHO it's
> not to be performed from within grass given that this operation
> makes no sense "geographically".
I agree,
> Don't know what the context is, but if you just have to rotate an
> image output of a map maybe you'd better look towards image
> manipulation tools (e.g. imagemagick and the -rotate option, which
> can easily be integrated in a script process).
pnmrotate is another that I've used with d.out.gpsdrive and GpsDrive's
gdal_slice.sh script, together with 'g.region -n' to get the convergence
angle. (angle between local projection north vs true north)
render map with PNG driver in GRASS, read course-over-ground from Gpsd
(gpsd.berlios.de) in watcher mode, pnmrotate and pnmcrop, and then use
an image viewer which will update the display when the image changes.
(see grass 7 discussions about that).
Hamish
