[GRASS-user] Working with large images
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Sat Apr 25 17:27:49 EDT 2009
Ned:
> Thanks for responding. I installed the 6.4 RC4 binary from the "weekly
> snapshot". Is BigTIFF support only available if I compile from source?
Ned,
AFAIU it has to do with GDAL. If GDAL does not "see" big TIFFs then
GRASS is not going to "see" them as well.
In Ubuntu repositories there is libgdal version 1.5 and I think it
supports (by default) BigTIFF. I am not sure though.
I always build from source so I've never had this problem. Maybe some
Ubuntero who's running osgeo-binaries?
If you like to try compiling you'll have to spent some time but you wull
get all stuff running fine. Check the wiki [1] and Dylan's notes [2]. I
can send you also my notes on osgeo under Ubuntu 64-bit.
Sorry for not being of any (practical) help, Nikos
[1]
http://grass.osgeo.org/wiki/Compile_and_install_GRASS_and_QGIS_with_GDAL/OGR_Plugin
[2] http://casoilresource.lawr.ucdavis.edu/drupal/node/123
