[GRASS-user] Working with large images
Moritz Lennert mlennert at club.worldonline.be
Sun Apr 26 10:49:07 EDT 2009
On 26/04/09 15:53, Ned Horning wrote:
> Moritz,
> When I run gdalinfo I get the following error: "ERROR 4: This is a
> BigTIFF file. BigTIFF is not support by this version of GDAL and libtiff"
Well, then maybe the libtiff version used does not support BigTIFF. No
expert on that. I guess that your best bet would be to recompile GDAL
yourself using with-libtiff=internal.
On Ubuntu compiling is rather easy:
0) apt-get install build-essential fakeroot
1) apt-get build-dep gdal #to install all the packages necessary for
compilation
2) mkdir gdal_src; cd gdal_src
3) apt-get source gdal # to download the source code + Ubuntu patches
4) cd into the source code directory created by 3)
5) edit debian/rules and add the line with-libtiff=internal to the
configure parameters (long list of similar parameters) - don't forget
the \ at the end
6) run 'fakeroot dpkg-buildpackage'
7) cd ..
8) sudo dpkg -i *.deb
Moritz
> The command line runs GDAL version 1.5.4
> Ned
> Moritz Lennert wrote:
>> On 26/04/09 12:13, Nikos Alexandris wrote:
>>> Nikos:
>>>>> In Ubuntu repositories there is libgdal version 1.5 and I think it
>>>>> supports (by default) BigTIFF. I am not sure though.
>>> Moritz:
>>>> In Intrepid and Jaunty it is 1.5 compiled with
>>>> --with-geotiff=internal, so it should work.
>>> Is this the same as "--with-libtiff=internal"?
>> No, sorry, your right, my bad.
>> The Ubuntu GDAL links to an external libtiff4 so this should take of it.
>> Ned, what does gdalinfo on the command line give you for this large
>> file ?
>> Moritz
