[GRASS-user] r.thin
Juan Carlos Torres Cantero jctorres at ugr.es
Sun Apr 26 15:04:20 EDT 2009
Danny
The algorithm run an iterative process. At each step its remove external cells
from the feature, and test if the result is correct. The parameter you must
enter to "iterations" is half the number of cell of your  wider line on the
map.
Juan Carlos Torres
On Sunday 26 April 2009 17:47:55 d c wrote:
> Hi,
> I'm trying to use r.thin before running r.to.vect.
> The man page says to use the thickness as parameter for *iterations*.
> I'm not sure I understand what it means by "thickness".
> Any ideas?
> Many thanks,
> Danny
