[GRASS-user] "ladders" in watershed delineation
Micha Silver
micha at arava.co.il
Sun Aug 2 04:49:35 EDT 2009
How can I avoid the problem of strings of single cells when creating
basins with r.watershed? I think this is referred to as "ladders".
Here's [1] an image showing what I mean.
In my example, the purple colored catchment has two "tails" of width 1
cell. One tail separates between the light green and the pale blue
catchments. The other (northern) tail splits the dark green catchment
into two.
After running r.to.vect to get the catchment vectors, I'm left with the
two "strings" or "ladders" of tiny vector areas. The southern string can
be removed with v.clean tool=rmarea with no ill effects.
However when I remove those small areas in the northern "ladder" I'm
left with the stream running *along the drainage divide* or even
zigzagging across the divide, neither of which is correct.
Can this problem be avoided? I've tried with a couple of different dem
sources, and at different resolutions and threshold values, but these
ladder phenomena always seem to appear.
This example was done with the ASTER DEM data, using a threshold of
11000 and resolution like the original data (1 arcsec ~= 30 m.)
Thanks,
Micha
[1] http://my.arava.co.il/~micha/ladders.html
