[GRASS-user] i.spec.unmix module
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Sun Aug 2 05:40:55 EDT 2009
Stefan Sylla:
> Hi, as there has not been an answer on that matter I would like to ask again,
> if someone can give an explanation on the i.spec.unmix AddOn problem with
> grass64.svn, as I got exactly the same messages as quoted below.
> Is it possible, that it has not yet been fitted with the sources of grass64?
> And if so, what can I do to get i.spec.unmix running?
Same error here using grass-6.4.0svn.
Nikos
> Pedro Camilo Alcantara wrote:
> > Hi everyone
> > I saw that there is a module on spectral unmixing on the add-ons
> > subversion
> > repository, so, I downloaded and compiled the last grass 6.4 snapshot
> > (grass-6.4.svn_src_snapshot_2008_06_14), download the addons with svn (svn
> > checkout https://svn.osgeo.org/grass/grass-addons/ grass-addons). and
> > compiled the module as described in the README I found on the addons (make
> > MODULE_TOPDIR=/home/camilo/grass-6.4.svn_src_snapshot_2008_06_14).
> > I got this messages:
> > /home/camilo/grass-addons/imagery/i.spec.unmix# make
> > gcc
> > -I/home/camilo/grass-6.4.svn_src_snapshot_2008_06_14/dist.i686-pc-linux-gnu/include
> > -g -O2       -DPACKAGE=\""grassmods"\"
> > -o OBJ.i686-pc-linux-gnu/main.o -c main.c
> > main.c: In function 'main':
> > main.c:172: warning: passing argument 2 of 'G_vector_norm_maxval' makes
> > integer from pointer without a cast
> > main.c:178: warning: passing argument 2 of 'G_vector_norm_maxval' makes
> > main.c:227: warning: assignment makes pointer from integer without a cast
> > main.c:231: error: expected expression before '[' token
> > main.c:231: error: too few arguments to function 'G_matrix_get_element'
> > main.c:231: error: 'mat_struct' has no member named 'G_matrix_get_element'
> > main.c:235: error: expected expression before '[' token
> > main.c:235: error: too few arguments to function 'G_matrix_get_element'
> > main.c:262: warning: assignment makes pointer from integer without a cast
> > main.c:263: error: 'mat_struct' has no member named 'm'
> > main.c:263: warning: assignment makes pointer from integer without a cast
> > main.c:264: error: 'mat_struct' has no member named 'm'
> > main.c:264: warning: assignment makes pointer from integer without a cast
> > main.c:265: error: 'mat_struct' has no member named 'n'
> > main.c:265: warning: assignment makes pointer from integer without a cast
> > main.c:266: error: 'mat_struct' has no member named 'm'
> > main.c:266: error: 'mat_struct' has no member named 'n'
> > main.c:266: warning: assignment makes pointer from integer without a cast
> > main.c:293: error: 'mat_struct' has no member named 'm'
> > main.c:293: warning: assignment makes pointer from integer without a cast
> > main.c:295: error: 'vec_struct' has no member named 've'
> > main.c:297: error: 'vec_struct' has no member named 've'
> > main.c:306: error: 'mat_struct' has no member named 'n'
> > main.c:307: error: 'vec_struct' has no member named 've'
> > main.c:307: error: 'mat_struct' has no member named 'n'
> > main.c:324: error: 'mat_struct' has no member named 'n'
> > main.c:325: error: 'vec_struct' has no member named 've'
> > main.c:326: error: 'vec_struct' has no member named 've'
> > main.c:339: warning: assignment makes pointer from integer without a cast
> > main.c:349: error: 'vec_struct' has no member named 've'
> > main.c:383:28: warning: missing terminating " character
> > main.c:383: error: missing terminating " character
> > main.c:384: error: expected ')' before numeric constant
> > main.c:384: error: stray '\' in program
> > main.c:385: error: stray '\' in program
> > main.c:386: error: stray '\' in program
> > main.c:387:11: warning: missing terminating " character
> > main.c:387: error: missing terminating " character
> > main.c:391: error: expected ';' before '}' token
> > make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
> > I am using a debian server with Linux 2.6.22-3-686 #1 SMP Sun Feb 10
> > 20:20:49 UTC 2008 i686 GNU/Linux
> > Is there any other way to compile this module? or is just that is under
> > development?
> > Best
> > camilo
