[GRASS-user] "ladders" in watershed delineation
Micha Silver
micha at arava.co.il
Tue Aug 4 07:32:24 EDT 2009
Markus Metz wrote:
> Micha Silver wrote:
>> Markus Metz wrote:
>>> These single-cell strings in basins, did you get them with SFD or
>>> MFD mode? If MFD mode, what convergence factor did you use?
>> My watershed delineation was done with r.watershed, not r.terraflow,
>> so IIUC it's SFD. I didn't see any "braided" streams in the output.
> r.watershed in 6.5+ can do MFD which reduces these single-cell strings
> substantially. I would recommend MFD over SFD for anything with 30m
> resolution or higher, not much gained for 90m or coarser. Results are
> generally more accurate with MFD for high resolution (<= 30m) DEMs.
Markus:
Thanks for your time.
So, bottom line, I'll look forward to updating to 6.5 or 7...
> Markus M
