[GRASS-user] [GRASS-dev] error on gui startup - solved
Hamish
hamish_b at yahoo.com
Thu Aug 6 21:14:13 EDT 2009
Mark wrote:
> On my kubuntu 9.04, the rgb.txt file was in another location than the
> previous solution, but "locate" found it in /usr/share/vim/vim72/rgb.txt
> I put that in the /etc/X11 directory and rebooted and all is good.
> On upgrading a system to 9.04, the file was still in /etc/X11, on a new
> install it was not there.
tip:
on debian-like distros you can run: "apt-file search rgb.txt" and it will
tell you the package to install to add the missing file.
probably there is some x11-* package containing it not installed and the
Vi copy is just one of a number of clones.
Hamish
