[GRASS-user] Geodatabase and GRASS GIS - how to get the data out
of a geodatabase
Agustin Diez Castillo
adiez at uv.es
Sun Aug 9 10:45:24 EDT 2009
I've tried the R solution w/o success, see below
On Aug 9, 2009, at 8:35 AM, Markus Neteler wrote:
> On Sun, Aug 9, 2009 at 3:23 AM, stephen sefick<ssefick at gmail.com>
> wrote:
>> I have a GIS database that is in .mdb format (microsoft access). I
>> have found mdb tools through my debian package manager, but now I
>> don't know how to get the data out of the the database and into
>> GRASS.
>> There are x and y coordinates and other things in the database. Is
>> there a tutorial on how to get the data into GRASS from this
>> database?
> I see two ways:
> 1) via unixODBC
> For Linux, you need "unixODBC" to be installed (your preferred
> distribution
> most likely contains this package). As done, get also the MDB Tools,
> compile it with unixodbc support enabled if not already done.
> Then follow instructions at http://www.gdal.org/ogr/drv_pgeo.html
> 2) via R
> R
> install.packages('Hmisc', dependencies=TRUE)
> library(Hmisc)
> # Read all tables in the Microsoft Access database blabla.mdb
> # perhaps better change to Locale in which the .mdb file was
> # generated to avoid that accented table column names are
> # getting lost.file first
> d <- mdb.get('/path/to/blabla.mdb')
> contents(d)
> for(z in 1:length(d)) print(attributes(d)$names[z])
returns to me with
sh: mdb-tables: command not found
> There you are. Now write out to something else with the "foreign"
> package:
> install.packages('RSQLite', dependencies=TRUE)
> library(RSQLite)
> drv <- dbDriver("SQLite")
> con <- dbConnect(drv, dbname = '/tmp/blabla.db')
> dbWriteTable(con, "mynewtable", d)
> dbDisconnect(con)
> Now you can open '/tmp/blabla.db' with 'sqlite3' or
> other software, e.g. GRASS (import with db.in.ogr).
> Cheers
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090809/c9e0f8d8/attachment.html
