[GRASS-user] Geodatabase and GRASS GIS - how to get the data out
of a geodatabase
Dylan Beaudette
dylan.beaudette at gmail.com
Sun Aug 9 11:33:06 EDT 2009
I have used 'mdbtools' in the past for this type of operation.
However, this will only extract attribute data-- not geometry data. I
think that you will need a windows build of GDAL/ORG to accomplish
that. Check the GDAL page.
Here are some examples of using the mdbtools package:
http://casoilresource.lawr.ucdavis.edu/drupal/node/462
Cheers,
Dylan
On Sun, Aug 9, 2009 at 8:19 AM, William
Kyngesburye<woklist at kyngchaos.com> wrote:
> Markus,
> I was trying to get mdbtools working on OSX this weekend (yet another
> attempt), and thought your R method might be an alternative. But that also
> requires mdb-tools - that's where mdb-tables tool is found.
> Agustin: If I remember right, you're on OSX? If so, you are out of luck, I
> have yet to find or compile a working MDB library for OSX.
> On Aug 9, 2009, at 9:45 AM, Agustin Diez Castillo wrote:
>> I've tried the R solution w/o success, see below
>> On Aug 9, 2009, at 8:35 AM, Markus Neteler wrote:
>>> On Sun, Aug 9, 2009 at 3:23 AM, stephen sefick<ssefick at gmail.com> wrote:
>>>> I have a GIS database that is in .mdb format (microsoft access). I
>>>> have found mdb tools through my debian package manager, but now I
>>>> don't know how to get the data out of the the database and into GRASS.
>>>> There are x and y coordinates and other things in the database. Is
>>>> there a tutorial on how to get the data into GRASS from this database?
>>> I see two ways:
>>> 1) via unixODBC
>>> For Linux, you need "unixODBC" to be installed (your preferred
>>> distribution
>>> most likely contains this package). As done, get also the MDB Tools,
>>> compile it with unixodbc support enabled if not already done.
>>> Then follow instructions at http://www.gdal.org/ogr/drv_pgeo.html
>>> 2) via R
>>> R
>>> install.packages('Hmisc', dependencies=TRUE)
>>> library(Hmisc)
>>> # Read all tables in the Microsoft Access database blabla.mdb
>>> # perhaps better change to Locale in which the .mdb file was
>>> # generated to avoid that accented table column names are
>>> # getting lost.file first
>>> d <- mdb.get('/path/to/blabla.mdb')
>>> contents(d)
>>> for(z in 1:length(d)) print(attributes(d)$names[z])
>> returns to me with
>> sh: mdb-tables: command not found
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Mon Dieu! but they are all alike. Cheating, murdering, lying, fighting,
> and all for things that the beasts of the jungle would not deign to possess
> - money to purchase the effeminate pleasures of weaklings. And yet withal
> bound down by silly customs that make them slaves to their unhappy lot while
> firm in the belief that they be the lords of creation enjoying the only real
> pleasures of existence....
> - the wisdom of Tarzan
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
