[GRASS-user] Geodatabase and GRASS GIS - how to get the data out
of a geodatabase
William Kyngesburye
woklist at kyngchaos.com
Sun Aug 9 13:55:06 EDT 2009
Well, don't get your hopes up. I had a little better success this
time, but it seems to be ignoring blob fields, which is how the
coordinate data is stored. A commercial ODBC driver that looked
promising a few years ago has a nasty bug getting blob data, and still
hasn't been fixed (...time to bug the developers again).
One possibility is to use a virtualized Linux to use GDAL+mdb-tools.
VirtualBox is free, though I'm using Parallels with no trouble.
Ubuntu runs great virtualized.
On Aug 9, 2009, at 12:39 PM, Agustin Diez Castillo wrote:
> You're right William, I'm on OSX and it seems that out of luck but
> in good hands as long as you are trying to get mdb in mac.
> I will keep an eye in any update about mdb-tools.
> Agustin
>> Markus,
>> I was trying to get mdbtools working on OSX this weekend (yet another
>> attempt), and thought your R method might be an alternative. But
>> that
>> also requires mdb-tools - that's where mdb-tables tool is found.
>> Agustin: If I remember right, you're on OSX? If so, you are out of
>> luck, I have yet to find or compile a working MDB library for OSX.
>> On Aug 9, 2009, at 9:45 AM, Agustin Diez Castillo wrote:
>>> I've tried the R solution w/o success, see below
>>> On Aug 9, 2009, at 8:35 AM, Markus Neteler wrote:
>>>> On Sun, Aug 9, 2009 at 3:23 AM, stephen sefick<ssefick at gmail.com>
>>>> wrote:
>>>>> I have a GIS database that is in .mdb format (microsoft
>>>>> access). I
>>>>> have found mdb tools through my debian package manager, but now I
>>>>> don't know how to get the data out of the the database and into
>>>>> GRASS.
>>>>> There are x and y coordinates and other things in the database.
>>>>> Is
>>>>> there a tutorial on how to get the data into GRASS from this
>>>>> database?
>>>> I see two ways:
>>>> 1) via unixODBC
>>>> For Linux, you need "unixODBC" to be installed (your preferred
>>>> distribution
>>>> most likely contains this package). As done, get also the MDB
>>>> Tools,
>>>> compile it with unixodbc support enabled if not already done.
>>>> Then follow instructions at http://www.gdal.org/ogr/drv_pgeo.html
>>>> 2) via R
>>>> R
>>>> install.packages('Hmisc', dependencies=TRUE)
>>>> library(Hmisc)
>>>> # Read all tables in the Microsoft Access database blabla.mdb
>>>> # perhaps better change to Locale in which the .mdb file was
>>>> # generated to avoid that accented table column names are
>>>> # getting lost.file first
>>>> d <- mdb.get('/path/to/blabla.mdb')
>>>> contents(d)
>>>> for(z in 1:length(d)) print(attributes(d)$names[z])
>>> returns to me with
>>> sh: mdb-tables: command not found
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "Mon Dieu! but they are all alike. Cheating, murdering, lying,
>> fighting, and all for things that the beasts of the jungle would not
>> deign to possess - money to purchase the effeminate pleasures of
>> weaklings. And yet withal bound down by silly customs that make them
>> slaves to their unhappy lot while firm in the belief that they be the
>> lords of creation enjoying the only real pleasures of existence....
>> - the wisdom of Tarzan
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Dr. Agustín Diez Castillo
> Departament de Prehistòria i Arqueologia
> Phone: +34 963 86 42 42
> Avda. Blasco Ibañez, 28 Fax: +34 963 86 42 34
> València 46010
