[GRASS-user] Problem with the tcl/tk GUI
Maris Nartiss
maris.gis at gmail.com
Mon Aug 10 14:16:16 EDT 2009
Hello,
it's probably late for You, but can You, please, try 6.5 svn version?
IMHO I have fixed this issue. I would be thankfull for Your feedback.
Maris.
2009/6/16, Martin Mainzer <martmai at gmx.de>:
> Hello,
> I just installed the grass 6.4.0 RC4 *.rpm from
> http://download.opensuse.org/repositories/Application:/Geo/openSUSE_10.3
> on my OpenSuse 10.3 machine.
> Within the nc dataset I opened the sqlite mapset and copied the the
> geology map to the splite mapset with:
> ~> g.copy vect=geology at PERMANENT,geology
> Then I tried to show the attribute table of the geology map by using the
> tcl/tk GUI (the button in the lower part of the GIS Manager window). By
> clicking the button 'Show attribute data' the following command is sent
> to the GIS.m window:
> db.select table=geology
> database=/home/martin/GISDataBase/nc_spm_08/sqlite/sqlite.db driver=dbf
> Note the driver option! This command fails with the error:
> Cannot open dbf database:
> By correcting the driver option to sqlite everything works fine.
> By the way: v.db.connect -p geology shows the correct sqlite driver.
> Martin
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
