[GRASS-user] r.li help
William Kyngesburye
woklist at kyngchaos.com
Mon Aug 10 18:04:46 EDT 2009
On Aug 10, 2009, at 1:44 PM, Markus Neteler wrote:
> On Mon, Aug 10, 2009 at 8:20 PM, Nathan Lemoine<lemoine.nathan at gmail.com
> > wrote:
>> I've attempted to find the config file on my harddrive and can't
>> seem to
>> locate it. It shows up when I run r.li.setup in the list of
>> available config
>> files and seems to load fine, but when i search for the file it
>> isn't on my
>> harddrive. The config file is supposed to be in the path ~/.r.li/
>> history,
>> but r.li.setup does not create such a path.
> Then that's perhaps the problem? William, does it create on your Mac
> the directory?
Yes, ~/.r.li/history was created for me. And my test config. It
looks sensible:
SAMPLINGFRAME 0|0|1|1
SAMPLEAREA -1|-1|0.03571428571428571|0.02631578947368421
MOVINGWINDOW
When I ran r.li.patchdensity, I got the segfault (same output and
crash log).
> Markus
>> I've run the r.le.setup which
>> creates the appropriate file path in my user folder to the r.le
>> config
>> files, but r.li does not seem to do this.
>> On Aug 10, 2009, at 12:49 PM, Markus Neteler wrote:
>>> Can you please send the config file to me?
>>> Markus
>>> PS: please keep the list in the loop since other may be able to help
>>> even better than me...
>>> On Mon, Aug 10, 2009 at 4:44 PM, Nathan Lemoine<lemoine.nathan at gmail.com
>>> wrote:
>>>> I copied landuse96_28m file to the user1 MAPSET (I named the copy
>>>> "landuse"), and used r.li.setup to make my config file. I named the
>>>> config
>>>> file "mov" and selected the "landuse" raster file. I set the
>>>> sampling
>>>> frame
>>>> to the whole region, and set the sampling area to a moving
>>>> window. I
>>>> chose a
>>>> rectangular window of 5x5 cells. The config file was the set and
>>>> seemed
>>>> to
>>>> be fine. I attempted to run r.li.patchnum rast=landuse config=mov
>>>> output=test and got the following reports:
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
