[GRASS-user] Low map display resolution in default 6.4 ?
    Markus Neteler
    neteler at osgeo.org
    Fri Aug 14 17:52:08 EDT 2009
Hi Felix,
On Fri, Aug 14, 2009 at 11:43 PM, Felix Schalck<felix.schalck at gmail.com> wrote:
> 1. DEM resolution:
> $gdalinfo srtm_38_03.tif
> Pixel Size = (0.000833333333333,-0.000833333333333)
> 2. Region settings:
> $g.region -p
> nsres:      0:00:03
> ewres:      0:00:03
which corresponds to:
g.region -g
nsres=0.000833333333333331
ewres=0.000833333333333333
That should be fine, but...
> If I interpret those numbers correctly, the region is set to the
> theoretical max. resolution. Again, since I basically did not touch
> the configs during the upgrade procedure (GRASS 6.23>6.4RC5) I thought
> to myself it might just be a configuration change of the default
> driver used by d.rast: in the old version, it took forever to load,
> but the level of details SEEMED much higher, now it loads quasi
> instantly, but looks 'soappy'. What changed ?
(nothing should have changed)
... did you use d.erase to tell the GRASS monitor about the high
resolution? The technology behind all is still the same in 6.4.
Markus
