[GRASS-user] Low map display resolution in default 6.4 ?
Hamish
hamish_b at yahoo.com
Fri Aug 14 19:20:58 EDT 2009
Felix wrote:
> 2. Region settings:
> $g.region -p
> projection: 3 (Latitude-Longitude)
> nsres: 0:00:03
> ewres: 0:00:03
> rows: 31200
> cols: 55200
> cells: 1722240000
unless you have some very large monitor, I would suggest to
set the resolution to say 0:01 for display purposes.
g.region res=0:01 -ap
raise it again if you need to do processing.
64 bit computer? or was it compiled with large file support?
(your region is huge)
what does r.univar say about it?
Hamish
