[GRASS-user] Network analysis
David Dabin
david.dabin at gmail.com
Mon Aug 17 03:21:38 EDT 2009
Dear Grass Users/Developpers,
I am studying the distribution of car accidents on a road network. In order
to define hotspots and hotzones (succession of hotspots on a road) based on
a local density of accidents computed on the network, I use the v.net.alloc
function (to allocate a subnet to each accident event). For the moment, the
density is thus expressed per "Thiessen" segment. To illustrate, Typical
output is similar to
----x---|---x-|-x--|--x----
where
x: is the location of one or many accidents,
-: is a piece of the network,
|: is the limit of the Thiessen segments
My density of accident is simply the number of accident divided by the
length of the Thiessen segment. Howerver, as you can notice from the
example, the Thiessen segments (|---x-|) are not symmetric relatively to the
accident location. I thus would like to compute the length on the right and
on the left of each segment. I have tried to cut the output of v.net.alloc
with v.edit and coordinates of accident but it do not works. Do you have an
idea on how to proceed and which function should I use or implement?
Thanks in advance,
David
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090817/dd3c2a15/attachment-0001.html
