[GRASS-user] r.li help
Nathan Lemoine
lemoine.nathan at gmail.com
Mon Aug 17 10:40:15 EDT 2009
per Hamish I used some more gdb commands and got some more information:
(gdb) r.li.patchnum map=northrast conf=whole output=test
Starting program: /Applications/GRASS-6.4.app/Contents/MacOS/bin/
r.li.patchnum .li.patchnum map=northrast conf=whole output=test
Reading symbols for shared libraries .++++++. done
Program received signal EXC_BAD_ACCESS, Could not access memory.
Reason: KERN_INVALID_ADDRESS at address: 0x0000000000000008
0x00007fff806b0964 in strcmp ()
(gdb) bt full
#0 0x00007fff806b0964 in strcmp ()
No symbol table info available.
#1 0x000000010005bc63 in parseSetup ()
#2 0x000000010005c899 in calculateIndex ()
#3 0x00000001000008c8 in start ()
(gdb) l
1 /var/tmp//cc9BQQ7d.s: No such file or directory.
in /var/tmp//cc9BQQ7d.s
(gdb) frame 2
(gdb) l
1 in /var/tmp//cc9BQQ7d.s
it looks like this is the file where the information is getting lost.
i hope this helps a bit more.
On Aug 17, 2009, at 2:35 AM, Hamish wrote:
> Nathan Lemoine wrote:
>> I've tried running gdb on the r.li.patchnum program, but I have no
>> debugging or programming experience, so I can only report the
>> error messages I've received. running the program normally, without
>> of gdb, gets me the error:
>> Illegal filename. Character <> not allowed.
>> WARNING: Unable to open header file for raster map <@(null)>
>> CHILD[pid = 326]: unable to open mask ... continue without!!!
>> this error message typically just repeats itself.
>> running the program with gdb gets me:
>> Starting program:
>> map=northrast conf=whole out=test
>> and if I backtrace:
>> (gdb) bt
> you've done well with the backtrace Nathan, after so many months we
> finally know where this bug is. I think Paolo might buy you a beer.
> (gdb on Linux didn't give me much to go on, only that it finished
> with error code 1)
> see https://trac.osgeo.org/grass/ticket/718#comment:16
> r.li.daemon is using strtok() in its multi-thread code, but that
> function
> is not safe to use with threads and so the jobs collide and the
> program
> breaks. Because r.li.daemon always starts 10 jobs, it breaks even if
> you
> don't have a multi-processor CPU.
> "The strtok() function uses a static buffer while parsing, so it's
> not thread safe."
> It doesn't look like it will be very hard to fix, but it's slightly
> beyond my talents to do so.
> Hamish
> ps- for future reference, if you use "bt full" in gdb you get the
> value
> of all variables, and if you type "l" you see which line in the source
> code it got to. http://grass.osgeo.org/wiki/Bugs#Using_GDB
