[GRASS-user] Multiple v.net.path parameters
achim
ak7 at jupiter.uni-freiburg.de
Mon Aug 17 10:56:59 EDT 2009
Hamish schrieb:
> > achim wrote:
>> >> In attached example it is possible to calc path from 1 to 4
>> >> and from 5 to 6, but not from 1 to 2,3,5,6 or from 5 to anywhere
>> >> expect 6 and so on.
>> >> Do you have an idea how to handle this?
>> >> Especially: do you know if "breaking the lines" (eg. dark
>> >> green one at point 5) is possible with networking techniques?
> > from the image the little "+"s indicate there are nodes at all
> > intersections, so there is nothing to break really. (unless there
> > are two lines on top of each other, in which case you can do v.clean
> > remove duplicates tool)
> > if you want each line to have it's own color/cat use v.category option
> > to remove all cat numbers then again to add new ones sequentially. you
> > might have to do that in another column and then change the key column
> > to the new one with v.reclass.
> > Hamish
In my test-area I get for this network:
type count min max
point 0 0 0
line 466 1 466
boundary 0 0 0
centroid 0 0 0
area 0 0 0
all 466 1 466
Layer: 2
type count min max
point 642 1 642
line 0 0 0
boundary 0 0 0
centroid 0 0 0
area 0 0 0
all 642 1 642
after revoming duplicates (and re-categorization) the same
so its nothing about the and categories :) .
after v.cleak=break (and re-categorization) I get:
type count min max
point 0 0 0
line 619 1 619
boundary 0 0 0
centroid 0 0 0
area 0 0 0
all 619 1 619
Layer: 2
type count min max
point 642 1 642
line 0 0 0
boundary 0 0 0
centroid 0 0 0
area 0 0 0
all 642 1 642
so automatically it doe's something in nearly the right way
(see http://article.gmane.org/gmane.comp.gis.grass.user/31102 for this)
The breaking tool does not work, so I try doing it with network-tools.
A
