[GRASS-user] v.edit break ERROR: Attempt to delete dead feature
achim ak7 at jupiter.uni-freiburg.de
Tue Aug 18 09:34:32 EDT 2009
Hi all,
so I wrote a little script as workaround I want to share
while renew_cats just looks like:
v.category input=$1 output=$1_nocat option=del type=$3 layer=$2 --o
v.category input=$1_nocat output=$1 type=$3 layer=$2 --o
Its really slow, but does its job,
Greetings,
Achim
achim schrieb:
>> both reported issues are serious bugs of v.edit. Can you fill trac
>> ticket for that? Just to avoid that it will forgotten. I will try to
>> take a look ASAP.
> I'll write a report then.
> Do you (or anyone else) have an idea how else to get the lines splitted
> on these points?
> Achim
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
-------------- nächster Teil --------------
Ein Dateianhang mit Bin?rdaten wurde abgetrennt...
Dateiname   : break_rivernetwork_correct.sh
Dateityp    : application/x-shellscript
Dateigr??e  : 1625 bytes
Beschreibung: nicht verf?gbar
URL         : http://lists.osgeo.org/pipermail/grass-user/attachments/20090818/21ab264a/break_rivernetwork_correct.bin
