[GRASS-user] creating map series purely on ps.map
maning sambale
emmanuel.sambale at gmail.com
Thu Aug 20 04:54:31 EDT 2009
Basically my workflow for creating paper maps is create the main map
in ps.map. Export the ps output to pdf or png in a graphics software
(scribus or illustrator). Edit all map elements legend, anotations,
etc.
What I want is to be bale to create the map purely within grass and
ps.map module.
Several questions:
1. I need to prepare separate mapsheets of landcover data. I have a
vector layer in grass of all the boundingboxes. How can I call ps.map
to create mapsheets using the individual boundingboxes as the region
settings?
2. Each mapsheet requires a different locatormap as reference. How do
I add the locatormap using a bigger region settings around the mapped
region settings?
3. Legend symbology for different landcover categories within a single
polygon vector. As a workaround, I separate landcover categories as
separate vector layers.
4. Tips and tricks for different annotations.
5. Combine different ps.map output into one map.
Any advice? Thanks in advance!
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
