[GRASS-user] Re: grass-user Digest, Vol 40, Issue 40
Richard Chirgwin
rchirgwin at ozemail.com.au
Thu Aug 20 17:44:21 EDT 2009
grass-user-request at lists.osgeo.org wrote:
> Send grass-user mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> http://lists.osgeo.org/mailman/listinfo/grass-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> grass-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-user digest..."
> Today's Topics:
> 1. attribute info attached to multiple areas (Sharon M)
> 2. creating map series purely on ps.map (maning sambale)
> 3. Re: creating map series purely on ps.map (Hamish)
> 4. v.to.rast error? (Paolo Cavallini)
> 5. magic? (achim)
> 6. Re: v.to.rast error? (Hamish)
> 7. Re: v.to.rast error? (Paolo Cavallini)
> 8. Re: magic? (achim)
> Message: 1
> Date: Thu, 20 Aug 2009 09:44:34 +0930
> From: Sharon M <morrisxs09 at gmail.com>
> Subject: [GRASS-user] attribute info attached to multiple areas
> To: grass-user at lists.osgeo.org
> Message-ID:
> <7a0cde410908191714ja3439dbw36f1c112428157ca at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> Hi,
> I'm using WinGRASS-6.4.0SVN-r38537-1 (on Windows XP) and imported a
> .MIF/.MID files via v.in.ogr using default settings. I get the
> following message
> "6 areas represent more (overlapping) features, because polygons
> overlap in input layer(s). Such areas are linked to more than 1 row in
> the attribute table. The number of features for those areas is stored
> as category in layer 2."
> I've identified one of these (overlapping) areas and found the vector
> data contains an area completely surrounding another area. The problem
> is the outside area's attribute information is also being attached to
> the inside area - how can this association be removed as the inside
> area has it's own attribute information?
> Any help would be appreciated.
> Thanks,
> Sharon
Sharon,
Since you don't have that many areas to deal with, you could do it
manually. What you want to do is get the outside area without the inside
area - the doughnut without the hole!
For example, in v.digit you could attach a centroid to the outside area,
and then fill in its information from the database.
Richard Chirgwin
