[GRASS-user] problems with compile i.landsat.acca add-onn
Hamish hamish_b at yahoo.com
Sat Aug 22 22:07:46 EDT 2009
Saami Riet wrote:
> I'm new with working with Grass.
> I try to use the extension i.landsat.acca to reduce the
> influence of clouds
> in a Landsat Tm szene.
> Trying to compile the script  wich i downloaded from
> http://svn.osgeo.org/grass/grass-addons/imagery/ don't
> work on my computer.
> Mayby i do something wrong.
> I have enjoy the README in the grass-addons SVN:
> "Installation - Code Compilation"
> http://trac.osgeo.org/grass/browser/grass-addons/README.
> But it dos'nt work.
> I work on a
> UBUNTU Version 9.04
> Grass 6.4.0~rc4-3
> The path to Grass  is:
>  /usr/lib/grass64
> The path to the downloaded i.landsat.acca-files is:
> $home/i.landsat.acca
> I used the terminal-window under Ubuntu for the commands.
> I'm in the path $home/i.landsat.acca .
> The command i used is:
> make MODULE_TOPDIR=/usr/lib/grass64/
> The answer from my magical machine is:
> Makefile:8: /usr/lib/grass64//include/Make/Module.make: No
> such file or
> directory
> make: *** Keine Regel, um
> »/usr/lib/grass64//include/Make/Module.make« zu
> erstellen.  Schluss.
if grass was installed from a package, was the grass-dev
package installed too?
or did you compile from source code? if so point to the source
directory.
Hamish
