[GRASS-user] "opening Grass problem"
achim
ak7 at jupiter.uni-freiburg.de
Mon Aug 24 03:40:30 EDT 2009
as far as I know, it is not possible to install grass from inside qgis.
There you can install a plugin, that allows you to use grass from inside
qgis. So you have to install grass seperatly.
Depending on your operating system, you can install grass gis from here:
http://grass.itc.it/download/index.php
Achim
juan carlos millord schrieb:
> Im so new in grass gis, so i look for help on freenode and told me about
> the mail list
> ,there i found out that i could install it from the qgis package, and i
> did it, now when i try to open it this appeare:
> Error setting region (Problem with g.region?):
> child process exited abnormally
> and after that one this:
> g.proj or projectionn error:ERROR:G_getenv():
> Variable LOCATION_NAME not set
> what i have to do?
> All suggestion will be welcome!
> thx,
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
