[GRASS-user] "installing grass issue"
achim ak7 at jupiter.uni-freiburg.de
Mon Aug 24 12:25:08 EDT 2009
Hello Juan Carlos,
yes, all packages have to be installed.
Im using OpenSuse and Im not a Debian expert. Maybe an Debian-user can
give you a hint how to install all these packages.
juan carlos millord schrieb:
> Appears to be that when i try to install grass from a .deb package it
> has a lot of dependencies, and ok i downloaded them  but those decencies
> have more downloading have more and is like never ends.
> Is there a way to install it with all the dependencies together?
> since i used apt-get with this result:
>  juanchy:/home/criacuervo/Desktop# ls
> grass_6.0.2-6_i386.deb           libpq4_8.1.17-0etch1_i386.deb
> libgdal1-1.3.2_1.3.2-4_i386.deb
> juanchy:/home/criacuervo/Desktop# dpkg -i libgdal1-1.3.2_1.3.2-4_i386.deb
> Selecting previously deselected package libgdal1-1.3.2.
> dpkg: regarding libgdal1-1.3.2_1.3.2-4_i386.deb containing libgdal1-1.3.2:
>  libgdal1-1.5.0 conflicts with libgdal1-1.3.2
It seems, here you have a problem with two versions of gdal:
just instal one of them.
Achim
>   libgdal1-1.3.2 (version 1.3.2-4) is to be installed.
> dpkg: error processing libgdal1-1.3.2_1.3.2-4_i386.deb (--install):
>  conflicting packages - not installing libgdal1-1.3.2
> Errors were encountered while processing:
> *And i almost forget, i used Debian 5.0*
> this is a copy of my /etc/sources.list
> deb cdrom:[Debian GNU/Linux 5.0.2 _Lenny_ - Official i386 DVD Binary-1
> 20090628-15:08]/ lenny contrib main non-free
> deb http://security.debian.org/ lenny/updates main contrib  non-free
> deb-src http://security.debian.org/ lenny/updates main contrib  non-free
> deb http://volatile.debian.org/debian-volatile/ lenny/volatile
> <http://volatile.debian.org/debian-volatile/lenny/volatile> main
> contrib  non-free
> deb http://http.us.debian.org/debian/ lenny main
> deb-src http://volatile.debian.org/debian-volatile/ lenny/volatile main
> contrib  non-free
> deb http://debian.gfoss.it/ lenny main
> deb http://debian.unesr.edu.ve/debian/ lenny main
> deb http://debian.ues.edu.sv/debian/ lenny main
> i tried with qgis, and i installed it i thought, but was a pluging i
> think because when i try to open it this appears:
>     > Error setting region (Problem with g.region?):
>     > child process exited abnormally
>     > and after that one this:
>     > g.proj or projectionn error:ERROR:G_getenv():
>     > Variable LOCATION_NAME not set
>     > what i have to do?
>     > All suggestion will be welcome!
>     > thx,
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
