[GRASS-user] problems with v.to.rast? -- some updates
    Carlos Grohmann
    carlos.grohmann at gmail.com
    Mon Aug 24 13:42:52 EDT 2009
Dears,
After some tests, I managed to convert the lines to a raster. I had to
create a new polygon layer from the original raster and convert this
polygon to lines IN ARCGIS, then import the new shapefile. This tells
me that:
There is something wrong with r.to.vect, as it appears to me that
there was no database connection (even after running db.connect). This
error propagated to v.types.
Best
Carlos
Carlos Henrique Grohmann - Geologist D.Sc.
a.k.a. Guano - Linux User #89721
ResearcherID: A-9030-2008
http://digitalelevation.blogspot.com
http://www.igc.usp.br/pessoais/guano
_________________
Can’t stop the signal.
