[GRASS-user] some issues of GRASS on Fedora 11
    Laura Poggio
    laura.poggio at gmail.com
    Wed Aug 26 03:05:34 EDT 2009
I had similar issues with fedora 11 64 bit.
I compiled the Grass 6.4 svn snapshot of the 15-08-2009 on a fedora 11 64
bit system. Everything went fine without errors. However when I open GRASS I
get the following error:
GRASS 6.4.0svn (DEM):~ >
/usr/lib64/python2.6/site-packages/wx-2.8-gtk2-unicode/wx/_core.py:14450:
UserWarning: wxPython/wxWidgets release number mismatch
  warnings.warn("wxPython/wxWidgets release number mismatch")
The gui (wx) is starting, but the 3D view and the digitize do not start. For
the 3d view I get a "loading data" message and nothing is happening.
I tried the same with the svn of 6.5 and I get the same messages. But even
the 2d data are not loading.
I do not have two versions of Python on the machine. However I have the 2.6
installed.
A couple of weeks ago I installed grass on a fedora 10 64 bit with the same
options and everything is working fine. But there the version of Python is
2.5.
I put a message on the fedora forum, but I did not get any answer. And in
the repository the latest official version is still the 6.3. That is why I
went into compiling it.
Thank you
Laura
2009/8/26 Martin Landa <landa.martin at gmail.com>
> Hi,
> 2009/8/26 ambrish dhaka <ambijat at hotmail.com>:
> > 1. Error in digitization tool
> > Unable to initialize display driver, see README file for more
> information.
> > Details: 'NoneType' object has no attribute 'OpenMap'
> > (/usr/lib/grass-6.3.0/etc/wxpython/vdigit/_grass6_wxvdigit.so: undefined
> > symbol: _ZN10wxPseudoDC9AddToListEP5pdcOp)
> First of all I would suggest to you to use more recent version of
> GRASS (note that wxGUI is under development).
> > 2. Some mismatch issue
> > GRASS 6.3.0 (projectAfghanistan):~ >
> > /usr/lib/python2.6/site-packages/wx-2.8-gtk2-unicode/wx/_core.py:14450:
> Probably more versions of Python installed on your machine?
> Martin
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa<http://gama.fsv.cvut.cz/%7Elanda>
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090826/3e9c2c78/attachment-0001.html
