[GRASS-user] r.watershed and bridges
achim
ak7 at jupiter.uni-freiburg.de
Wed Aug 26 09:13:37 EDT 2009
If you have a small region and you know, where the bridges are, I guess
fastest method is to do it manually.
Otherwise r.carve would do good here.
To find bridges maybe the gradient of hight will help (slope).
Best regards,
Achim
Micha Silver schrieb:
> Using the new ASTER DEM data it seems to me that the resolution is good
> enough to show the elevation of the road surface on bridges crossing a
> riverbed. I see some places where the delineated stream comes to a
> bridge, then, instead of going under the bridge, turns 90 deg and runs
> along the road to a low spot, then crosses. So the bridge is "seen" a
> dam. What's the best way to deal with this? r.carve? or just locally
> editing the raster somehow?
> Thanks,
> Micha
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
