[GRASS-user] Unable to get an horizon from a DEM using r.horizon
Mathieu Monney
mathieu.monney at xwaves.net
Thu Aug 27 07:56:46 EDT 2009
Hi all,
My goal is to extract the visible horizon given a point using a DEM I
have successfully imported into GRASS. Using the r.horizon command it
returns me some good result for some part of the horizon. However at
some other angle in returns me the 0 value which means that no horizon
has been found. I cannot understand why we cannot found a horizon.
There always be an horizon, even if a point lies on lower altitude
than you. I have tried to modify the r.horizon command to return
horizon values which are also below you but it doesn't work well and
returns me some weird results.
Anyone having some clues about that?
Thank you a lot in advance.
Best,
Mathieu Monney
