[GRASS-user] The projections and transformations
Ravinder Singh Bhalla rsbhalla at gmail.com
Sun Aug 30 18:51:32 EDT 2009
Hi Ambrish,
I'd suggest you use Q-GIS for the display of the maps with different
projections. It happily reads GRASS rasters and vectors. It also has a
neat plugin to convert from on projection to another.
Note however that Q-GIS is not a replacement for GRASS in terms
geo-processing.
Cheers
Micha Silver wrote:
> ambrish dhaka wrote:
>> Hello! ALL,
>> I need to learn the important way of working with the data having
>> different projection system for a single location. Usually the case is
>> between long lat and UTM projections. I set the region first with
>> g.region and then try to import vector data which is in long lat
>> format they do not get "on the fly" transformation in the GRASS and
>> what I find that they cannot be displayed in my region.
> GRASS does not do "on the fly projection". There are some good
> explanations on the list why "on the fly" isn't such a good idea. {1}
>> The second question is that is it possible to create two different
>> mapsets, one in Long lat and other in UTM for the same location and
>> then work upon these two simultaneously even displaying them.
> No, you don't work that way. You need two separate LOCATIONs, one for
> UTM and a second for LAT/LON. Then use r.proj or v.proj to pull maps
> from one to the other. MAPSETs are for sets of maps which are logically
> related: same work project or in the same place, etc. But everything in
> one MAPSET must be in the same projection and LOCATION.
> Micha
> [1]
> http://n2.nabble.com/link-to-datasets-from-other-locations-td3185792.html#a3193823
>>  I hope to get some very good guidance on these issues.
>> thanks!
>> Ambrish Dhaka
>> Are you an untamed, bizarre or daring explorer? Find out now! Drag n'
>> drop <http://www.ExploreMyWay.com>
>> This mail was received via Mail-SeCure System.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
