[GRASS-user] v.vol.rst error
Markus Neteler
neteler at osgeo.org
Mon Aug 31 16:42:05 EDT 2009
On Mon, Aug 31, 2009 at 7:26 PM, xavier garcia
acosta<epistacio at hotmail.com> wrote:
> Hello all,
> I would like to use the v.vol.rst module but when I try to execute them from
> the GRASS GUI this error text appears in the terminal:
> GRASS 6.4.0RC4 (costabrava):~ > *** buffer overflow detected ***: v.vol.rst
> terminated
> ======= Backtrace: =========
> /lib/tls/i686/cmov/libc.so.6(__fortify_fail+0x48)[0xb7792da8]
> /lib/tls/i686/cmov/libc.so.6[0xb7790eb0]
> /lib/tls/i686/cmov/libc.so.6[0xb77905a8]
> /lib/tls/i686/cmov/libc.so.6(__overflow+0x53)[0xb7703683]
> /lib/tls/i686/cmov/libc.so.6(__printf_fp+0x176e)[0xb76db26e]
> /lib/tls/i686/cmov/libc.so.6(_IO_vfprintf+0x3ca)[0xb76d4bfa]
> /lib/tls/i686/cmov/libc.so.6(__vsprintf_chk+0xa4)[0xb7790654]
> /lib/tls/i686/cmov/libc.so.6(__sprintf_chk+0x2d)[0xb779059d]
> v.vol.rst(main+0x176)[0x804c966]
> /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe5)[0xb76ab775]
> v.vol.rst[0x804bd71]
> ======= Memory map: ========
> 08048000-08056000 r-xp 00000000 08:06 347205
> /usr/lib/grass64/bin/v.vol.rst
> 08056000-08057000 r--p 0000d000 08:06 347205
> 08057000-08058000 rw-p 0000e000 08:06 347205
> 08a25000-08a46000 rw-p 08a25000 00:00 0 [heap]
> Anybody know how to fix that?
> Pd: My GRASS version is GRASS 6.4.0RC4 (2009) runnig on UBUNTU 9.04
I have used v.vol.rst in GRASS 6.4 for more than 22000 UTM maps
without problems.
Please tell use the parametes you used (idealy the command line), or,
even better, an example to reproduce it with either Spearfish or the
North Carolina
data set. Which projection?
Markus
