[GRASS-user] Re: Georectify problem
Richard Chirgwin
rchirgwin at ozemail.com.au
Tue Dec 1 23:01:23 EST 2009
Adam,
If all else fails, work with a command line process ... I've never had
happy experiences with the purely GUI rectification.
i.group (groupname) (mapname)
i.target (groupname) Target_Location Target_Mapset
d.mon X0
i.points (groupname) - this launches the GCP capture GUI (old style,
X-windows but it works!)
i.rectify (groupname) extension="something" order=(polynomial order)
RC
> Message: 1
> Date: Mon, 30 Nov 2009 14:38:04 -0700
> From: Michael Barton <michael.barton at asu.edu>
> Subject: Re: [GRASS-user] Georectify problem
> To: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
> Message-ID: <6C956E66-153C-4152-809E-B4C28AB7442A at asu.edu>
> Content-Type: text/plain; charset=US-ASCII; format=flowed; delsp=yes
> Given the platform you are on and the fact that you are using an up-to-
> date build of GRASS 6.4, I recommend you do this with the new wxPython
> GUI instead of the TclTk one. I think it will work better for you.
> Michael
> On Nov 30, 2009, at 2:16 PM, grass-user-request at lists.osgeo.org wrote:
>> Date: Mon, 30 Nov 2009 09:57:42 -0800
>> From: Adam Dershowitz <adershowitz at exponent.com>
>> Subject: [GRASS-user] Georectify problem
>> To: GRASS user list <grass-user at lists.osgeo.org>
>> Message-ID: <684BACB4-CEAF-4CDD-98D1-9F3EE5742C1C at exponent.com>
>> Content-Type: text/plain; charset=us-ascii
>> I am trying to georectify an xy image. I think that I am doing
>> things correctly yet I keep getting an error. Perhaps someone can
>> clear things up for me.
>> I imported the image into an XY location. I then went to the
>> location that I want to import into and brought up a map so I could
>> click on points.
>> If then select file-> georectify. I fill in the info and then click
>> Start georectifying. It brings up the manage ground control points
>> window and a display showing the xy map to be georectified. If I
>> click there I can add the GCP xy coords. But if I then click in my
>> original window to select the georgraphic coords I get an error:
>> can't read "b1 coords" : no such variable.
>> can't read "b1coords": no such variable
>> while executing
>> "$geoentry insert 0 $b1coords"
>> invoked from within
>> "if { [info exists geoentry] } {
>> (command bound to event)
>> I can't figure out why it will not let me select the points. I have
>> selected the arrow tool in the map display.
>> I am using a Mac with William Kyngesburye's binary builds. I have
>> 6.4 RC5-3 Snow with OS 10.6.2
>> Thanks,
>> --Adam
> Message: 2
> Date: Mon, 30 Nov 2009 14:40:45 -0700
> Subject: Re: [GRASS-user] Trouble setting location and projection
> Message-ID: <01B9BF6F-B613-45FA-8520-38EC61489D50 at asu.edu>
>> Date: Mon, 30 Nov 2009 13:03:16 -0600
>> From: Ross Benisch <benisch89 at hotmail.com>
>> Subject: [GRASS-user] Trouble setting location and projection
>> To: <grass-user at lists.osgeo.org>
>> Message-ID: <COL121-W561C882825F5984EB916E8B6970 at phx.gbl>
>> Content-Type: text/plain; charset="iso-8859-1"
>> I am trying to set the project location and cordinate system using
>> the 6.4.0svn version for windows but I keep getting the projection
>> error,
>> 'g.proj.exe-p' when I try and start Grass. I have a GIS background
>> and I am frustrated that I can't get it to work. I want to use the
>> projection nad83UTM Zone 14N. I have read through all of the
>> tuturiols and help sheets and looked at the FAQs with no such luck.
>> I really want to use this program to help with my job so if you
>> would help me get started I would greatly appreciate it.
>> Sincerely,
>> Ross Benisch
> Can you give us some more specific information? Are you using the
> location wizard? Is this the newest windows binary? Which version of
> Windows are you using? What exactly is the error message that you get?
> Michael
> Message: 3
> Date: Tue, 01 Dec 2009 01:37:43 +0100
> From: Helmut Kudrnovsky <hellik at web.de>
> To: grass-user at lists.osgeo.org
> Message-ID:
> <5304763.17158.1259627864390.JavaMail.fmail at fmcert01.dlan.cinetic.de>
> Content-Type: text/plain; charset="iso-8859-15"
>> I am trying to set the project location and cordinate system using the 6.4.0svn version for windows but I keep getting the projection error,
>> 'g.proj.exe-p' when I try and start Grass. I have a GIS background and I am frustrated that I can't get it to work. I want to use the projection nad83UTM Zone >14N. I have read through all of the tuturiols and help sheets and looked at the FAQs with no such luck. I really want to use this program to help with my job so >if you would help me get started I would greatly appreciate it.
>> Sincerely,
>> Ross Benisch
> hi Ross,
> please open a bug report at
> https://trac.osgeo.org/grass/wiki
> by specifying Windows-Installer, steps to reproduce the error, Windows-version etc.
> so important information can't get lost in the mailing list
> best regards
> Helmut
> ___________________________________________________________________________________
> Pop-Diva Sarah Kreuz und ihr beeindruckendes Debütalbum
> "One Moment in Time". Jetzt reinhören! http://produkte.web.de/go/05/
> -------------- next part --------------
> A non-text attachment was scrubbed...
> Type: application/pkcs7-signature
> Desc: S/MIME Cryptographic Signature
> Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20091201/0ed6f741/smime-0001.bin
> Message: 4
> Date: Tue, 01 Dec 2009 01:45:50 +0100
> Message-ID:
> <9735556.17178.1259628351250.JavaMail.fmail at fmcert01.dlan.cinetic.de>
>>> 'g.proj.exe-p' when I try and start Grass. I have a GIS background and I am frustrated that I can't get it to work. I want to use the projection nad83UTM >Zone >14N. I have read through all of the tuturiols and help sheets and looked at the FAQs with no such luck. I really want to use this program to help with >my job so >if you would help me get started I would greatly appreciate it.
>>> Sincerely,
>>> Ross Benisch
>> hi Ross,
>> best regards
>> Helmut
> maybe related to following bug report:
> http://trac.osgeo.org/grass/ticket/827
> please add your comments
> best regards
> Helmut
> Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20091201/c3375ab2/smime-0001.bin
> Message: 5
> Date: Tue, 01 Dec 2009 01:48:12 +0100
> From: Marco Tuckner <marcotuckner at public-files.de>
> Subject: [GRASS-user] i.atcorr with MSS band 5,6,7
> Message-ID: <hf1p4d$stq$1 at ger.gmane.org>
> Content-Type: text/plain; charset=ISO-8859-15
> Dear Grass users,
> how can I add spectral conditions of the bands 5,6,7 of the Landsat MSS
> sensor?
> I have seen that these are defined in:
> http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/imagery/i.atcorr/Iwave.cpp
> But is is unclear to me how they are added.
> As far as the manual concerned, the pre-defined spectral conditions are
> only available to LS MSS band 1-4:
> http://grass.itc.it/grass64/manuals/html64_user/i.atcorr.html
> 31 mss (landsat5) band 1 (0.475-0.640)
> 32 mss (landsat5) band 2 (0.580-0.750)
> 33 mss (landsat5) band 3 (0.655-0.855)
> 34 mss (landsat5) band 4 (0.785-1.100)
> Thanks in advance for any hints,
> Marco
> Message: 6
> Date: Mon, 30 Nov 2009 21:14:48 -0800
> From: mhall at berkeley.edu
> Subject: Re: [GRASS-user] i.atcorr with MSS band 5,6,7
> To: "Marco Tuckner" <marcotuckner at public-files.de>
> Cc: grass-user at lists.osgeo.org
> Message-ID:
> <65b87b606fc185067cf55224e63558f9.squirrel at calmail.berkeley.edu>
> Content-Type: text/plain;charset=utf-8
> I thought the MSS sensor only had 4 bands, and the TMS sensor sensor 7?
> Best, MEH
>> Dear Grass users,
>> sensor?
>> Marco
>> grass-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Message: 7
> Date: Tue, 01 Dec 2009 01:32:53 -0500
> From: Peng Du <du at cs.utk.edu>
> Subject: [GRASS-user] reading a column/vector of a raster image
> Message-ID: <4B14B895.906 at cs.utk.edu>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Hi all
> I am dealing with a satellite image which has N bands, each band of size
> row x col. Is there any way to read one column of a certain band or all
> the bands of a certain point? I only found G_get_raster_row which works
> for row.
> Thanks,
> Peng
> Message: 8
> Date: Tue, 1 Dec 2009 09:53:10 +0300
> From: "Mithoefer, Klaus" <kmithoefer at icipe.org>
> Subject: [GRASS-user] Execution failed g.proj.exe
> To: "'grass-user at lists.osgeo.org'" <grass-user at lists.osgeo.org>
> Message-ID: <3A03213F2C680F429897406A814DE6AA082F9DE4C0 at icipedudumx1>
> Dear List,
> I just installed WinGRASS-6.4.0svn-r39740-2-Setup.exe on Windows XP professional and when starting the system using the spearfish database I get the message Error in command execution: Execution failed g.proj.exe -p .
> Any ideas?
> Bes regards,
> Klaus
> Klaus Mithöfer
> Geographic Information Systems (GIS) Officer
> icipe - International Centre of Insect Physiology and Ecology
> P.O. Box 30772 - 00100
> Nairobi, Kenya
> Phone: +254-20-8632000, Extn. 2147
> Fax: +254-20-8632001/2
> Mobile: +254-724-308404
> E-Mail: kmithoefer at icipe.org
> web: www.icipe.org
> This position is supported by German development cooperation //
> Centre for international Migration and Development - http://www.cimonline.de/en/index.asp
> Klaus.mithoefer at cimonline.de
> Message: 9
> Date: Tue, 01 Dec 2009 10:56:55 +0100
> Message-ID:
> <7848421.22602.1259661416896.JavaMail.fmail at fmcert01.dlan.cinetic.de>
>> Dear List,
>> I just installed WinGRASS-6.4.0svn-r39740-2-Setup.exe on Windows XP professional and when starting the system using the >spearfish database I get the message Error in command execution: Execution failed g.proj.exe -p .
>> Any ideas?
>> Bes regards,
>> Klaus
> please add your comments to following bug report:
> by specifying the situation when the error comes up.
> best regards
> Helmut
> Preisknaller: WEB.DE DSL Flatrate für nur 16,99 Euro/mtl.!
> http://produkte.web.de/go/02/
> Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20091201/13673d61/smime.bin
> End of grass-user Digest, Vol 44, Issue 1
