On Thu, 3 Dec 2009, Alfredo Alessandrini wrote: > There is a shell command for set "computational region from display"? Alfredo, Are you referring to g.region? Use it specifying the map name; e.g.: g.region vect=streams or g.region rast=elevation HTH, Rich
