[GRASS-user] Problems displaying d.vect.thematic
    Omar Bautista González
    omarbautistag at gmail.com
    Mon Dec  7 08:29:00 EST 2009
Hello:
The problem is with the d.vect.thematic command. It don't display
nothing on the monitor. Even when other commands do it right.
I did the following commands:
> d.mon x0
> d.vect.thematic -s map=JCE_M2006 type=area column=RD_ALIANZA  layer=1 icon=basic/circle size=5  maxsize=20 nint=4 pointcolor=255:0:0  linecolor=0:0:0 startcolor=255:0:0 endcolor=0:0:255  themetype=graduated_colors monitor=none  themecalc=interval colorscheme=blue-red;
And nothing is displayed. Here are the output errors:
Segmentation fault
Thematic map legend for column RD_ALIANZA of map JCE_M2006
Value range: -
Mapped by 4 intervals of -inf
Color(R:G:B)	Value
0:0:255		 -
DBMI-DBF driver error:
SQL parser error: syntax error, unexpected AND processing 'and'
in statement:
SELECT cat FROM JCE_M2006 WHERE RD_ALIANZA >=  and RD_ALIANZA<=
Error in db_open_select_cursor()
85:0:170		 -
in statement:
SELECT cat FROM JCE_M2006 WHERE RD_ALIANZA >  and RD_ALIANZA<=
170:0:85		 -
in statement:
255:0:0		 -
in statement:
I installed ubuntu 6.10 on a Dell Mini 10. Then from the repositories
I installed GRASS 6.4.0RC5.
This is very strange because other commands are displaying well. Like
the following:
d.vect.chart map=PuntosCentralesM2006
type=point,line,boundary,centroid  layer=1
columns=C_PLD,C_PRD,C_PRSC,C_OTROS  ctype=pie ocolor=black
sizecol=P_OTROS size=15 scale=1 colors=purple,white,red,yellow;
I tried also with the GUI having the same problem.
Regards,
- Coordinador de Investigación para el Desarrollo,
Diseño, Monitoreo y Evaluación
Visión Mundial República Dominicana
