[GRASS-user] grass-7.0.svn with gdal installation problem on
	ubuntu9.10
    Jarosław Jasiewicz
    jarekj at amu.edu.pl
    Wed Dec  9 10:02:28 EST 2009
Pankaj Kr Sharma pisze:
> Hello group,
> I have run it with grass-6.5.svn but the same gdal and gdal-grass
> plugin are not working with grass-7.0.svn.
> Any suggestions!
> Thanks.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
This is because different library version for grass65 and 7. This will
also repeated if you using R. If you will try run spgrass on R from
grass7 you will se following error:
Incompatible library version for module. You need to rebuild GRASS
     or untangle multiple installations.
GRASS 6.5.svn (nc_spm_08):~ >
suggestion:
import data and run R in grass65 which is fairy stable, use 7 only for
testing
Or
create new user and install locally both gdal and grass7 locally for
that user
HTH
J.
