[GRASS-user] v.to.rast conversion
Giacomo Piva
piva at meeo.it
Wed Dec 9 11:41:09 EST 2009
Hi all,
I have already read and tested how to integrate the GRASS modules on a
BASH script as Markus suggested.
I'm running GRASS 6.4RC5 version.
I should convert a shapefile given in the Italian projection system
(Gauss-Boaga) into a raster file (GeoTIFF format) at a given resolution.
I have tried to use the v.to.rast module, but it first requires the
import module v.in.ogr.
So, I found some troubles in the region defining.
I've tried to set it manually with the command:
g.region s=... n=... e=.. w=..
But the command returns the following error:
ERROR: default region is not set.
I've tried also other solutions, as the command:
g.region vect="path/to/file.shp"
But it returns the same error.
Could anyone give me any suggestions?
Thank you.
Giacomo
Markus Metz wrote:
> Hi Giacomo,
> are you by any chance running this command outside a GRASS session? If
> grass is running, there is no need to give the full path, typing
> v.to.rast help
> in the terminal where grass is running is enough. Also, grass should
> know where to look for libgrass_vect.so, no need to run ldconfig. If
> you really want to use grass modules outside a standard grass session,
> see the grass book [1], third edition, page 338, 9.3 Automated usage
> of GRASS.
> Hope that helps,
> Markus M
> [1] http://www.grassbook.org/
