[GRASS-user] g.region (was v.to.rast conversion)
    Giacomo Piva
    piva at meeo.it
    Thu Dec 10 10:55:54 EST 2009
Sorry for the change of the topic.
Hi Achim,
First of all, thanks for your reply.
To clarify my problem, i want to specify that the main problem is that
all command that involves the g.region always returns the reported error
(ERROR: default region is not set.) also the "help".
I found a similar discussion here:
http://lists.osgeo.org/pipermail/grass-user/2009-November/052988.html
Where the solution was to use of the SVN version of the grass.
I already tried to use that version, bunt nothing changed.
Any me any suggestions?
Thank you.
Achim Kisseler wrote:
> Hi,
> it says:  "default" region is not set. Try
> g.region -s
> to save as fefault region
> eventually use
> v.in.ogr -e
> to extend the location extends
> Achim
> Giacomo Piva schrieb:
>> Hi all,
>> I have already read and tested how to integrate the GRASS modules on a
>> BASH script as Markus suggested.
>> I'm running GRASS 6.4RC5 version.
>> I should convert a shapefile given in the Italian projection system
>> (Gauss-Boaga) into a raster file (GeoTIFF format) at a given resolution.
>> I have tried to use the v.to.rast module, but it first requires the
>> import module v.in.ogr.
>> So, I found some troubles in the region defining.
>> I've tried to set it manually with the command:
>> g.region s=... n=... e=.. w=..
>> But the command returns the following error:
>> I've tried also other solutions, as the command:  g.region
>> vect="path/to/file.shp"
>> But it returns the same error.
>> Could anyone give me any suggestions?
>> Thank you.
Giacomo
