[GRASS-user] center of gravity: solution
Achim Kisseler
ak7 at jupiter.uni-freiburg.de
Fri Dec 11 04:50:24 EST 2009
> beware it will only be "valid" for small ranges of latitude.
> otherwise the weights of the longitudes at high latitudes will
> have more weight in the average than they should.
Hi Hamish,
yes, you are right.
In this case the area had to be projected in a projection, where every
raster-cell has the same size.
Otherwise a "lat-depending" weighting could help... I will try it soon.
Thanks for your comment,
Achim
