[GRASS-user] Compiling GRASS 6.4.0RC5 on AIX 5.3
Fri Dec 11 13:20:58 EST 2009
Mike Waldron wrote:
> I have successfully compiled GRASS 6.4.0RC5 on RedHat Enterprise Linux
> 5. I am also trying to compile it on AIX 5.3 and having a great deal of
> difficulty.
> Has anyone successfully compiled it on AIX 5.3? If so, can you please
> provide the configure options and any compiler-related environment
> variables that you used?
If you get configure errors, please post the relevant portion of
config.log (everything from the "checking for ..." message
corresponding to the failed test to the end of the file). Don't worry
about error messages for tests which ultimately pass; those are quite
normal.
If configure succeeds but you get compilation errors, post the
relevant portion of the output from "make" (from the "Entering
directory ..." to the matching "Leaving directory ..." for a directory
which fails). If you get errors building a library, anything which
depends upon the library will fail, so only post the errors relating
to building the library itself.
