[GRASS-user] Compiling GRASS 6.4.0RC5 on AIX 5.3
    Mike Waldron
    mwaldron at email.unc.edu
    Mon Dec 14 08:12:27 EST 2009
Thanks, I will try the weekly snapshot source.
Mike
Hamish wrote:
>> I have gotten the configure to run
>> successfully. Here is a portion of the make that has a
>> failure. It is in a library so this obviously has a
>> cascading effect of causing many other modules to fail to
>> compile.
> Hi just to note before you run into the problem ...
> there was a nasty bug in the 6.4.0rc5 release which messed up
> the region settings. you'll probably want to use the 6.4 release
> branch SVN or weekly snapshot instead. hopefully we'll issue a
> rc6 soon, and shortly thereafter the final 6.4.0.
> regards,
> Hamish
