[GRASS-user] Compiling GRASS 6.4.0RC5 on AIX 5.3
Glynn Clements
glynn at gclements.plus.com
Mon Dec 14 17:50:13 EST 2009
Mike Waldron wrote:
> Yes, I copied the ldAix script from the Tcl/Tk package.
> After attempting all the suggestions, I finally used --disable-shared on
> the configure command, and all but a handful of modules successfully
> compiled. I was able to individually address the ones that failed
> through Makefile edits and several small source code/header file edits.
Is there anything which ought to be changed in GRASS itself?
